Using MCUXpresso with FRDM board
2,841件の閲覧回数
Circuit_Man
Hi NXP,
I have the FRDM-KE02Z40M board. I am trying to run my code in MCUXpresso, but I get the following error messages when I try to run. I have attached snapshots of the errors. The second snapshot has more details of the error. I don't know how to resolve this issue. Thanks.
10 返答(返信)
2,842件の閲覧回数
ErichStyger
Senior Contributor V
Do other examples/projects work fine? Or is it just this project?
And you did use the 'blue' debug icon, right?
Could it be that launching the gdb executable is blocked by your firewall? Try disabling it, or check if there is a 'confirm access' or similar dialog in the background.
I hope this helps,
Erich
2,824件の閲覧回数
Circuit_Man
Hi Erich,
This is my first program using MCUXpresso and the FRDM-KE02Z40M board.
I clicked on the blue Debug icon and another box opened, whose snapshot is attached. It is asking if I have probes. I do not have any probes (MCUXpresso CMSIS-DAP, P&E micro probes, nor SEGGER J-Link probes). Do I need to purchase these probes in order to test my code or is there a way I can bypass this probes dialog box and continue testing my code?
Thanks.
2,816件の閲覧回数
ErichStyger
The FRDM board has an on-board circuit, programmed by default as P&E probe as far as I know. But if you are using Windows 10 and if the board came with an outdated bootloader, it possibly has been put back in a non-working mode. See https://mcuoneclipse.com/2016/08/01/bricking_and_recovering_opensda_boards_in_windows_8_and_10/ about recovering it, or how to update it: https://mcuoneclipse.com/2014/11/01/illustrated-step-by-step-instructions-updating-the-freescale-fre...
I hope this helps,
Erich
タグ(1)
2,798件の閲覧回数
Circuit_Man
Hi Erich,
I have the FRDM-KE02Z40M board. Will the FRDM-KE02Z files work for my KE02Z40M board?
2,747件の閲覧回数
ErichStyger
yes, they should.
2,791件の閲覧回数
Robin_Shen
Hi Circuit_Man,
If the bootload and firmware works on your PC, then you don't need to update it. If not, I think the MSD-DEBUG-FRDM-KE02Z_Pemicro_v118.SDA can be used, since I didn't see the file for 40MHz FRDM board.
Robin
2,781件の閲覧回数
Circuit_Man
Hi Robin,
I have successfully updated the bootloader on my FRDM-KE02Z40M board. But I get the following error when I build my code. The error message is attached and the error is circled in red. The error is saying "Program file does not exist." Does this have something to do with my PC's directory structure? As you can see, I am new to using MCUXpresso. Thanks in advance.
2,742件の閲覧回数
ErichStyger
"Program file does not exist" means that the .axf file has not been created. Your screenshot shows that there is a build error, so your application was not able to compile/link. You need to fix this first.
2,772件の閲覧回数
myke_predko
Senior Contributor III
@Circuit_Man
In your screen shot you are covering the build results but it looks like the "Build failed" (It's cut off by the error window).  If that's the case, then of course there isn't a build file, it's only created when the build completes successfully.
Please confirm the state of the build.
2,811件の閲覧回数
Robin_Shen
Hi Erich,
Thanks for your help!
Recovering OpenSDA Boards with Windows 10
One of my customer told me: When I rebooted and double checked that the services were stopped. They were not and I had to re-stop them. Then started working as described. Got the boot loader and app code flashed and verified.
Maybe it was the reason sometimes that approach seems not to work?
Robin
