USB host communication with more devices
586 次查看
Luky
I will develop a new project and I need to communicate between one USB host device (maybe Kinetis K or KL) and more devices (8bit MC9S08JS16). Devices will connect to USB host over USB HUB. This is my idea. I haven´t had any experience with USB Stack yet. I need to know if it is possible. Thanks for the answer.
Lukas
470 次查看
jeremyzhou
Hi Lukas,
I don't think your scheme could achieve.
Selecting a KL or K series MCU as the USB host device can handle the devices whose total number is based on the USB modules the USB host contains under without using the USB HUB.
In another word, if you want to the USB host device communicate with three or more devices, it can't work it out certainly.
Hope the reply helps.
Ping
471 次查看
jeremyzhou
Hi Lukas,
Ping
