Good morning
I installed the virtual com device in the demo app for the FRDM64. The device status is
The device cannot start. (Code 10)
Suggestions?
Thank You
Pietro
Hei Mark
All of the information are around the uTasker. And I don t see any source code, just binary files.. I need a project to use and the driver to start..
I have now not ant SDA to try and I try to solve the problem on another thread...
I wander if I am the only one with the CDC driver not starting...
So this computer has some crap...
Thank You
Pietro
Hi Pietro,
You can try the SDK_2.3_FRDM-K64F\boards\frdmk64f\usb_examples\usb_device_cdc_vcom
This code can be downloaded from this link:
Welcome | MCUXpresso SDK Builder
After you download the code, please follow the readme to operate it.readme.pdf is infolder:
SDK_2.3_FRDM-K64F\boards\frdmk64f\usb_examples\usb_device_cdc_vcom\bm
Please try it at first.
If you still have question about it, please kindly let me know!
Kerry
Thank You for assistance..
Effectively the driver I use is already coming from there. I tried the normal things, reinstall and restart the machine, it does not work the error is always there. I tried for similar problem in this community but it does not look a common problem. So what to do???
I am running a Windows 7 and the guidelines suggest something for Windows 8, the problem I see should not be there...
I tried anyway to look for a driver signature for this Windows but I do not find.
I hope there is a solution
Thank You
Pietro
Hi Pietro,
I have a question, if you don't run USB code, just run the helloword, whether the opensda COM can work on your side? J26 virtual port, can you find the com port in the win7, I also use the win7, it works Ok.
So, please try the opensda virtual com port at first.
Any updated information, please kindly let me know!
Kerry
Try some USB references from here, where you will also find drivers for all various Windows versions:
http://www.utasker.com/kinetis/FRDM-K64F.html
Mark
Kinetis: http://www.utasker.com/kinetis.html
Kinetis K64:
- http://www.utasker.com/kinetis/FRDM-K64F.html
- http://www.utasker.com/kinetis/TWR-K64F120M.html
- http://www.utasker.com/kinetis/TEENSY_3.5.html
- http://www.utasker.com/kinetis/Hexiwear-K64F.html
USB: http://www.utasker.com/docs/uTasker/USB_User_Guide.PDF
USB composites: http://www.utasker.com/kinetis/USB_Device.html
USB-CDC host<->device video: https://www.youtube.com/watch?v=XhISV1czIo4&list=PLWKlVb_MqDQFZAulrUywU30v869JBYi9Q&index=16
Free Open Source solution: https://github.com/uTasker/uTasker-Kinetis
Working project in 15 minutes video: https://youtu.be/K8ScSgpgQ6M
For better, faster, cheaper product developments consider the uTasker developer's version, professional Kinetis support, one-on-one training and complete fast-track project solutions to set you apart from the herd : http://www.utasker.com/support.html
Hei Mark
Thank You for the references. I am following the source of information.
The SDA on my FRDM board is not working, I always use the JTAG, and I am happy in this way. One time I put the header connector on the SDA and I deleted the SDA software on the other uP. I do not depend on the SDA so for me it is not important. I want to use the other USB port linked to the main processor and test the new serial port. it should not be a problem. I suppose.
I have another thread for restoring the SDA which is better to have working... that's another subject...
Thank You
Pietro
