UART problem using K70 with TWR-SER
1,372件の閲覧回数
juanmanuelpanie
I'm trying to communicate the K70 board with a PC via UART. I initialize the UART1 module and connect a serial cable between TWR-SER's DB9 connector to my PC, and finally I want to see the message at Hyperterminal window.
At the beggining, I have a doubt wich UART Module is driven to de DB9 connector. I have been looking at the schematics and I think that the module 1 is the correct. I do not know that it is a code problem or I am making a mistake with jumpers connections.
Here I paste the main code that I'm using:
int main(void)
  register uint16_t ubd;
  uint8_t temp;
  SIM_SCGC4 |= SIM_SCGC4_UART1_MASK;
  SIM_SCGC5 |= SIM_SCGC5_PORTC_MASK;
  PORTC_PCR4 |= 0x300;
  PORTC_PCR3 |= 0x300;
  PORTC_PCR2 |= 0x500;
  PORTC_PCR1 |= 0x500;
  UART1_C2 &= ~(UART_C2_TE_MASK | UART_C2_RE_MASK);
  UART1_C1 = 0;
  //ubd = (uint16_t)135;// ((20971520)/9600*16);
  //temp = UART0_BDH & ~(UART_BDH_SBR(0x1F));
  UART1_BDH = UART_BDH_SBR(0x00);
  UART1_BDL = UART_BDL_SBR(0x88);
  UART1_C2 |= UART_C2_TE_MASK;
  while(!(UART1_S1 & UART_S1_TDRE_MASK));
  UART1_D = (uint8_t) 'a';
  return 0;
P.D: I'm using CodeWarrior 10.6 IDE
792件の閲覧回数
mjbcswitzerland
Specialist V
Juan
The UART on TWR-SER and TWR-K70F120 is UART 2 and the pins to use are PTE16 (TX) and PTE17(RX).
You can get out-of-the-box code for this tower kit (UARTs in interrupt or DMA mode, TCP/IP and USB stack as well as FAT on SD card etc.) as well as a simulator for the K70 tower kit at http://www.utasker.com/forum/index.php?topic=1721.0
A screen shot of the simulator in operation is shown below.
Mark
4 返答(返信)
792件の閲覧回数
Kan_Li
Hi Juan,
Is this issue solved? Please kindly let me know if the problem is still there.
Kan
792件の閲覧回数
juanmanuelpanie
Hi Mark,
Thanks for the answer, I probed it today and it works. But I can not receive anything, I send well, but I tried to receive from the PC and nothing happend. I configured all register for enable the receiver, something that I should be missing with the code or with jumpers? Thanks
Juan Manuel
792件の閲覧回数
mjbcswitzerland
Specialist V
Juan
Which SW are you using?
At µTasker Test Software and Demos there is pre-built binary files for the K70 TWR kit which you can load. This will allow you to verify that the HW is Ok and all jumpers are correct.
The SW uses the UART so responds so you can see transmission at 115k Baud and verify that it responds to reception.
Mark
793件の閲覧回数
mjbcswitzerland
Specialist V
Juan
Mark
