I have a question about K40, i want to use FIFO receiver/ transmitter, but i dont know how can i reach insde FIFO data using uart_D register. Is there any example code about that or explanation. And i didnt understand purpose of watermark method.
Thanks a lot.
Ramazan
解決済! 解決策の投稿を見る。
Hi Ramazan,
The attachment provides the UART module transmit DMA test function (uart_tdre_dma_test()) and UART module receive DMA test function (uart_rdrf_dma_test()) separately.
And it also support the UART3, I'd like to suggest that you can verify these function one by one to your demo.
Ping
Hi Ramazan,
Please check the attachments which are used as validation code, I think it can help you out.
Ping
Hi jeremyzhou,
Thanks your answer and helpfull shairing. Actually, I sent some data with uart3_D register, but when i want to send using FIFO buffer, it doesnt succeed. my code is following. TCFIFO [TXCOUNT] doesnt count truely, it only count one time but i am sending 8 dataword, so it should be able to count 8. Where is the my fault. Is there any ideas about this.
unsgined int i, error=0;
void main(){
Uart_INIT(); // no -parity, 8-bit ,4800-baud, transmitter disable, receiver disable
UART3->PFIFO.TXFE = 1;
UART3->PFIFO.RXFE = 1;
UART3->C2.TE = 0;
UART3->C2.RE = 0;
/* Loop to fill the entire TxFIFO */
for(i=0;i<9;i++){
/* Write data into the FIFO */
UART3->D.RT = i;
/* Test to make sure TCFIFO is 8 (FIFO full) */
if ( UART3->TCFIFO.TXCOUNT != 8) { error++; }
/* Flush the TxFIFO */
UART3->CUART->FIFO.TXFLUSH = 1;
/* Test to make sure TCFIFO is 0 now (FIFO flushed) */
if ( UART3->TCFIFO.TXCOUNT != 0){ error++; }
/* Loop to fill the entire TxFIFO with a new data set */
for( i=0x11; i < 0x19; i++){
UART3->UART->D.RT = i;
/* Set the Rx watermark to 8 so that we can detect when the transmit is complete */
UART3->RWFIFO.RXWATER = 8;
/* Now re-enable the transmitter. This should cause all 8 bytes to transmit
UART3->C2.TE = 1;
Thanks for your interest,
Ramazan
6. UART0 and UART1 contains 8-entry transmit and 8-entry receive FIFOs
7. All other UARTs contain a 1-entry transmit and receive FIFOs
I saw in the datasheet. I used UART3, it has one dataword,for this reason TXCOUNT is counting 1. I missed out it. i will use uart0 for 8 dataword.
Thanks for your halp,
ramazan
Hi Ramazan,
Ping
