TWR-K53N512 with MED-EKG
533 次查看
soumyaks
I was just trying to use the TWR-K53N512 with MED-EKG. But as given in UserGuide, I donot have a TWR-SER. Can I use a TWR-K70F120M instead for connectivity?  Can I also get pointers on building this tower system?
Many Thanks,
Soumya
354 次查看
kerryzhou
Hi Soumya  KS,
    Please give me what the userguide you are reading.
    You can't use the TWR-K70F120M board instead of TWR-SER. But you can check it, what the detail function used with TWR-SER, you can find other hardware to replace. Take an example, if it is just use the UART, you can find a TTL to USB tool to replace the TWR-SER.
    But to work easily, it's better to work with TWR-SER:
Serial (USB, Ethernet, CAN, RS232/485) Tower System Module|NXP
Wish it helps you!
Kerry
