Is there a way to re-program the TWR-K21D50M tower module with its initial demo firmware to get it back into its "out of the box" state?
I'm trying to diagnose why I can't see any "hello world" output via the OSJTAG interface (USB to serial bridge).
已解决! 转到解答。
Hi Peter,
If you goto http://www.freescale.com/tower and then drill down to the Tower System Boards->Kinetis MCU Modules->TWR-K21D50M link.
The new web page has several methods to get the OOB (Out Of Box) code:
1) click on the Jump Start Your Design->Get started out of the box with TWR-K21D50M link. Then click on the TWR-K21D50M Sample Code.
2) click the Downloads tab, expand the Lab and Test Software (2) field to click on the TWR-K21D50M_SC_LAB code.
Both methods should download the same code (assumption...).
Once un-zipped you should be able to navigate to:
TWR-K21D50M Sample Code\TWR-K21D50M_SC\build\cw\TWR-K21D50M-OOBE
David
Hi Peter,
David
