TSI - TWR-K40 tsi demo
Fan_xy
When run the demo of TSI on TWR-K40 cw 10.6, I have some confused .
1)  I have not touch the pad , When the project get here see below, the register of TSI0_GENCS == 0x0053c2d2 ; this mean the bit "OUTRGF" and"EOSF" all "1" ,  mean out of range ,
While when continue click run
button, it does not run to the file of out of rang, see the screen shot
below.  Why ?
2)  After write to “1” to the flag of “EOSF  ” and “OUTRGF to clear the bits  both of them still “1”,
Please try on your side, why ?
Linda
vicentegomez
Hi Linda
Are you using the TWR-K40D100M? if this is the case the sample code is for the TWR-K40X256 that is rev 1 and the D100 is rev 2
There are some difference between the TSI module, you can check the application note AN4445 for more information.
I recommend that you create a new code using PE and the TSS library.
Please let me know if you need the sample code.
Vicente
Fan_xy
HI,
Now , I only want test the demo code . not want use TSS lib.
I use TWR_K40X256, and I also check the   demo read me  "tsi,txt"  , it said the board is also TWR_K40X256.
Please test on your said , and check the status of the register .
Thank
Linda
