TCP Socket programming using FRDM-KL25Z and mbed compiler
pratik
I have an issue related to TCP socket programming in mbed compiler.
I was search TCP socket program for mbed but "EthernetInterface.h" library not supported for FRDM-KL25Z.
I got an error "Error: #error directive: The Ethernet Interface library is not supported on this target in "TCPEchoClient/EthernetInterface/EthernetInterface.h".
So,Can you suggest me best running code or library for Socket programming ?
Thank you.
Pratik.
Tags (3)
