Signal generation through PWM + DMA
1,141件の閲覧回数
juanpablovega
Hi!
In my project I need to generate a signal, measure it and then analyse it.
Of course, I want the generation and the measurement not to load the CPU.
I've already been able to make the tuple PDB/ADC/DMA work, for the acquisition part. And it's just great.
Now, to generate the signal, I though that something like FTM/DMA/FTM(PWM) would work, but I can't manage to trigger the DMA with the first FTM.
I'm working with the PEx and I'm only using init_xxx components.
As for the FTM, I enabled the clock, the counter, the modulus, the external trigger with CNTIN, but nothing happened. When I say that nothing happened I mean that I never seem to be interrupted by the end of the major loop of the DMA.
As for the DMA, the source muxing is set to FTMx_CHx, and the rest is almost a copy of the other DMA component.
I'm lost... And I'm sure it's a really stupid problem.
Has anyone had any problem related to DMA triggering via the FTM?
Hardware: FRDM K20D50M
ラベル(2)
タグ(4)
2 返答(返信)
634件の閲覧回数
dhruvonline
Hi All,
Could you please post the  PDB/ADC/DMA(processor Expert) working code with K20 Device.
I have to measure the 10 channels continuously using the DMA. Request you to please suggest.
Regds,
Dhruv
634件の閲覧回数
jeremyzhou
Hi Juan,
I've inculded the sample code base on CW10.4 about FTM+DMA in the reply. I think it should be useful for reference and please refer to it for details.
If you have any other questions, please feel free to contact with me.
Have a nice day!
Ping
