Setting IPv4 of tower kit
709 次查看
prashantdev
I am using k60 tower kit. I've fnet stack for my application and I am not using any RTOS. Can anyone help me in setting the ipv4 address for my board.
标记 (5)
582 次查看
danielchen
HI Prashant:
If you are using FNET, I would suggest you refer to the FNET quick start guider.
Embedded TCP/IP stack: FNET Shell Demo Quick Start
You are able to change the default network parameters manually:
  • By using Shell commands:
    set address <default-if IPv4 address> set gateway <default-if IPv4 gateway address> set netmask <default-if IPv4 netmask address> set mac <default-if Ethernet address>
  • By changing the default values in the fapp_user_config.h source file.
    Your local system administrator is able to assign a unique IPv4 address for the board, and also provide you with the IPv4 addresses of the gateway and the netmask.
582 次查看
prashantdev
Thanx for ur quick response Daniel. Actually, I haven't used shell commands with microcontrollers. I've used them like initialize or setting up microcontroller through main() function. I am struggling with it since last week. If u can prove me any sample project then it would be a great help.
