See schematics, after the plate using Jlink debugging , but found the target voltage is only 0.4V much that I do wrong ?Battery Voltage : 3.1VJlink is intact , use other boards tested.
已解决! 转到解答。
Problem solving, is the power supply pin Jlink caused by poor contact。
never-displayed
