See schematics, after the plate using Jlink debugging , but found the target voltage is only 0.4V much that I do wrong ?
Battery Voltage : 3.1V
Jlink is intact , use other boards tested.
Solved! Go to Solution.
Problem solving, is the power supply pin Jlink caused by poor contact。
