Hi all,
I am facing a strange problem on a K64F interfaced to an SSD1306-based 128 x 64 OLED Display (following images); I use the FRDM-K64F and a FRDM-KL25Z with the MBED platform.
When I use the OLED display on the SPI port of the FRDM-KL25Z it works properly; when I use the same display or a twin one on the SPI0 port of the FRDM-K64F with the same code, all signals are correct except the MOSI one which is connected to the DIN line of the display: on the FRDM-K64F it appears greatly attenuated (almost with a factor of 10:1) or distorted with the shorter bits greatly attenuated and the display doesn't work at all.
I've tried also to use a different code on the FRDM-K64F sending the result of a 16-bit incrementing counter on the MOSI line and the result is the same: the signal is greatly attenuated until the MOSI line is connected to the DIN line of the display:
if I disconnect the MOSI signal from the display, it returns normal:
If I recompile and load the same code on the FRDM-KL25Z, the MOSI signal is always perfect!
NOTE: on both the previous pics the top waveform is the CS signal (used as the trigger) and the bottom signal is the MOSI one.
Here is the simple code I use to generate the previous signals:
#include "mbed.h"
#ifdef TARGET_K64F
#define SPI_SCK PTD1
#define SPI_MOSI PTD2
#define SPI_MISO PTD3
#define SPI_CS PTD0
#define I2C_SDA PTE25
#define I2C_SCL PTE24
#define displayDC PTC4
#define displayRST PTC3
#elif defined(TARGET_KL25Z)
#define SPI_CS PTD0
#define I2C_SDA PTE0
#define I2C_SCL PTE1
#define displayDC PTD5
#define displayRST PTA13
#endif
DigitalOut myled(LED_GREEN);
DigitalOut spi_cs(SPI_CS);
SPI spi(SPI_MOSI, SPI_MISO, SPI_SCK);
int main() {
uint16_t k = 0;
spi_cs = 1;
spi.format(8,3);
spi.frequency(2000000);
while(1) {
myled = !myled;
spi_cs = 0;
spi.write((k & 0xff00) >> 8);
spi.write(k & 0xff);
spi_cs = 1;
k++;
wait(0.1);
From the schematic of the FRDM-K64F it seems that the MOSI line of the SPI0 peripheral (PD2) is connected directly to the Arduino-like header whitout any series resistor and the same is on the FRDM-KL25Z; no other onboard peripherals are connected to these lines on both board.
Also, from the datasheet of the SSD1306, I read that the DIN signal is a normal digital input signal; no explicit note is reported about its input impedance.
For this reasons I am unable to find the cause of the MOSI attenuation on the K64F.
Is there anyone else that has tried to interface this kind of displays to the FRDM-K64F? If yes any hint will be appreciated!
已解决! 转到解答。
Hi Ma,
I am glad to inform you that finally I found the solution to this problem!
It was related to an undocumented configuration of the SPI port of the OLED display: on both my display samples (manufactured by WaveShare, .96inch OLED (B) | SPI I2C ) the DIN line was paralleled to some other internal signal by means of a 0R resistor (R1 in the following schematic diagram and pic):
Using a mixed signal oscilloscope I observed that the distortion of the DIN signal was limited to the initial part of the byte transferred from the FRDM-K64F to the display; carefully analyzing the circuit I found the 0R resistor and after its removal the display immediately started to work correctly!
I also verified that it is not necessary to enable the DSE bit of PORTD_PCR2.
Cheers.
Francesco
Please try to enable the PTD2 pin internal pull up with PORTD_PCR2 register and check if with the same issue.
Wish it helps.
Ma Hui
Hi Ma,
I tried to apply your hint adding the following code immediately after the declaration of the variable k in the main routine:
#ifdef TARGET_K64F | |
PORTD_PCR2 |= 0x03; | |
#endif |
Unfortunately nothing has changed: the MOSI/PTD2 signal appears in the same manner as I described in my first post.
Thank you anyway for your answer!
Francesco
Hi Francesco,
Thank you for the feedback.
I will do a test on my site and check if PTD2 pin with same issue on my site.
While, for I was engaged in a training this week and could that test next Monday.
Thank you for the patience.
Ma Hui
Hi Ma,
thank you for your willingness; in the meantime I did some other tries in the attempt to solve the problem by myself:
- I soldered an external pull-up resistor to the MOSI line: NO SUCCESS
- I changed the FRDM-K64F board with a twin one: NO SUCCESS
- I changed the SPI port connecting the OLED display to the RF/WIFI connector (J6), so now SCK = PTD5, CS = PTC12, MOSI = PTD6: NO SUCCESS.
In all my tries the aspect of the MOSI signal when attached to the display is always the same.
Any other hint will be appreciated.
Have a nice day.
Francesco
EDIT: carefully reading the data sheet of the "K64 Sub-Family Reference Manual" (Rev. 2, January 2014, http://cache.freescale.com/files/microcontrollers/doc/ref_manual/K64P144M120SF5RM.pdf) at page 283-284, I saw that in the PORTD_PCR2 register there is bit 6 named DSE (Drive Strength Enable), when set to 1, configures the high drive strength on the corresponding pin (PD2 in my case), if pin is configured as a digital output.
I tried to change the optional code valid only for FRDM-K64F to:
PORTD_PCR2 |= 0x40; | |
#endif |
Compiling the code, uploading it to the FRDM-K64F and capturing the MOSI signal on PD2 with the oscilloscope, it now appears exactly the same as the one I can see on the FRDM-KL25Z, even with PD2/MOSI connected to the display!
At the moment the display doens't show any output but, now that the most difficult problem is solved, it is only a matter of time and.. patience!
I will write here the complete description of the problem when (if...) I find it.
Francesco
Hi Francesco,
From the latest updates, when you set the [Drive Strength Enable] bit in PORTD_PCR2 register, you could get the SPI_MOSI signal as expected. Right?
The high drive strength will enhance the drive capability from 2mA to 8mA.
Ma Hui
Hi Ma,
Cheers.
Francesco
Hi Francesco,
Thank you for the update to let us know the root cause.
Ma Hui
Yes, this is the actual status of the problem: now I have a correct MOSI signal (as seen on the oscilloscope), but the display doesn't not display anithing yet; however I am working to solve this problem too.
Thank you for your help.
Francesco
