I am using a K40 Tower System with MQX4.0 CW10.3 and cannot get the ADC to do differential mode.
I used PE to set it up. ADC1, Differential, input-> PGA1_DP/ADC1_DP0/ADC0_DP3 and negatice ->PGA1_DM/ADC1_DM0/ADC0_DM3, Conversion time : 9.615385 µs, High voltage reference Vrefh_1_2V, Low voltage reference Vrefl_1_2V
My code from the example PE stuff builds and runs but all I get is 56891 to 56897, no matter what I put on the input lines ADC1_DP0 & ADC1_DM0.
Here is the code:
void main_task(uint_32 initial_data)
uint_16 atodValue;
MyADCPtr = AD1_Init((LDD_TUserData *)NULL); /* Initialize the device */
printf("\n\n-------------- Begin TJs Differential ADC example --------------\n\n");
while (TRUE)
_time_delay(5);
SampleGroup[0].ChannelIdx = 0U; /* Create one-sample group */
Error = AD1_CreateSampleGroup(MyADCPtr, (LDD_ADC_TSample *)SampleGroup, SAMPLE_GROUP_SIZE); /* Set created sample group */
Error = AD1_StartSingleMeasurement(MyADCPtr); /* Start continuous measurement */
//_time_delay(2); //while (!AD1_GetMeasurementCompleteStatus(MyADCPtr)) {}; /* Wait for conversion completeness */
while (ADC1_SC2 & 0x080);
Error = AD1_GetMeasuredValues(MyADCPtr, (LDD_TData *)MeasuredValues); /* Read measured values */
printf("%5d,\n ", *MeasuredValues);
printf("\ndone!\n");
_task_block();
Any help or ideas is much appreciated.
Thanks and cheers,
Tom
已解决! 转到解答。
Never mind, there is something goofy about how the ADCO_DP0 & DM0 run out to the tower card A27 & A28. I soldered wires right to the main board and all is good.
Also, PE Rocks!
Cheers,
Tom
I'm back onto this differential A/D stuff Monday. Anyone with any experience doing differential with a Kinetis Tower System. I'm just trying to help out an analog dude so he can test performance, it just needs it to work.
Cheers!
