PWM like signal during LLS
903件の閲覧回数
dusek_martin
I would like to generate square wave on some pin during sleep mode (e.g. LLS). Duty is not important, the frequency can be 1 kHz - 10 kHz.
Are there any options for MKL27? E.g. LPO, LPTMR, LPUART... ?
749件の閲覧回数
dusek_martin
This is not ideal as I will have to wake the MCU quite frequently.
I found out that it is possible to output LPO clock using SIM->SOPT1 = SIM_SOPT1_OSC32KSEL(3) | SIM_SOPT1_OSC32KOUT(1);
LPO runs even in LLS mode, so I have 1 kHz square wave everytime.
2 返答(返信)
749件の閲覧回数
nxf56274
In VLPW , You can use LPTMR to generate pwm. In the interrupt of lptmr, you toggle the IO‘s level. But in LLS, you can't generate the PWM. Because the pins will be latched.
TIC
750件の閲覧回数
dusek_martin
