Routines USB_Cdc_Allocate_Handle() and USB_Cdc_Free_Handle both walk through cdc_device_array.
cdc_device_struct_t cdc_device_array[MAX_CDC_DEVICE];
static usb_status USB_Cdc_Allocate_Handle(cdc_handle_t* handle)
uint32_t cnt = 0;
for (;cnt< MAX_CDC_DEVICE;cnt++)
if (cdc_device_array[cnt].controller_handle == NULL)
*handle = (cdc_handle_t)&cdc_device_array[cnt];
return USB_OK;
return USBERR_DEVICE_BUSY;
static usb_status USB_Cdc_Free_Handle(cdc_handle_t handle)
int32_t cnt = 0;
for (;cnt< USBCFG_DEV_MAX_CLASS_OBJECT;cnt++)
if (((cdc_handle_t)&cdc_device_array[cnt]) == handle)
OS_Mem_zero((void *)handle, sizeof(cdc_device_struct_t));
return USB_OK;
return USBERR_INVALID_PARAM;
If some poor maintenance guy changes USBCFG_DEV_MAX_CLASS_OBJECT, and forgets to update MAX_CDC_DEVICE, he will break USB_Cdc_Free_Handle().
The for-statement in USB_Cdc_Free_Handle()
should be identical to the for-statement in USB_Cdc_Allocate_Handle().
Solved! Go to Solution.
Hi John,
I'll report this issue to AE team for checking and thank you very much for your focus on Freescale product.
Ping
Hi John,
Ping
