MKE06 OR MKE16F512 RTOS(OR MQX)PROJECT
ahjg_xu
1. Now I use "mke06" and "mke16f" chips,
2. Using "MCUXpresso IDE"
If I want to build an "RTOS" or" MQX" project, how can I build a project?
danielchen
Hi @ahjg_xu
You can download MCUXpresso SDK for MKE16F and MKE06 from below link, FreeRTOS is supported in this package
https://mcuxpresso.nxp.com/en/select
If you want to use MQX Lite, I would suggest you use code warrior, KE06 project can be created.
myke_predko
Senior Contributor III
@ahjg_xu
I recommend that you start with FreeRTOS and start here: Kinetis K60 ARM Cortex-M4 Demo
