I would like to know the max current when VDD is 3.3v in KW36, but I could not find it in datasheet.
解決済! 解決策の投稿を見る。
最大是120mA
TIC
最大是120mA
TIC
May be this will help you.
TIC
Hi, I think the max supply current is unclear in this table.
The notice 2 has said the analog supply current is the sum of the active or disabled current for each of the analog modules on the device. We should see each module's specification for its supply current.
TIC
Hi, I sorry for my unclear expression. I would like to know the max current that KW36 can withstand.
The max current the IO can withstand is 3mA.
TIC
你好,我想问的是当KW36的供电电压是3.3v时,KW36能承受的最大的电流是多大
