KE16F Vs. KE18F
KE16F Vs. KE18F
993件の閲覧回数
JRIIS
Customer asking about the implication from a technical point of view if they change their design from the MKE16F to the MKE18F.
This should be the same die so it should be fine to use both as long at they compile to the actual version.
Could I kindly ask for validation on this please?
/Jakob
タグ(1)
3 返答(返信)
973件の閲覧回数
JRIIS
Hi Jing,
I need to understand all deference in detailed, when you say main difference is memory size then you indicate that there is other deference. Could you please point those out?
/Jakob
964件の閲覧回数
jingpan
KE18F has 2 CAN while KE16F has 1 CAN.
That's all I think.
Jing
982件の閲覧回数
jingpan
Hi Jakob,
Yes. Their main difference is memory size.
Jing
