K60N512 .data and .data_init definition.
951件の閲覧回数
Smiler
I am trying to resurrect my Freescale Tower TWR-K60N512 (MK60N512VMD100).
The IAR linker is complaining...
Linking
Error[Li005]: no definition for "__VECTOR_RAM" [referenced from C:\Users\Peter Goddard\Documents\Freescale Tower\Kinetis\hello_world\RAM_128KB\Obj\
startup.o]
Error[Li005]: no definition for "__VECTOR_TABLE" [referenced from C:\Users\Peter Goddard\Documents\Freescale Tower\Kinetis\hello_world\RAM_128KB\Obj\
startup.o]
Error[Li005]: no definition for "__BOOT_STACK_ADDRESS" [referenced from C:\Users\Peter Goddard\Documents\Freescale Tower\Kinetis\hello_world\
RAM_128KB\Obj\vectors.o]
Warning[Lp012]: no sections with name .data included - special symbol .data$$Base (referenced from C:\Users\Peter Goddard\Documents\Freescale Tower\
Kinetis\hello_world\RAM_128KB\Obj\startup.o) will be zero
Warning[Lp012]: no sections with name .data_init included - special symbol .data_init$$Base (referenced from C:\Users\Peter Goddard\Documents\Freescale
Tower\Kinetis\hello_world\RAM_128KB\Obj\startup.o) will be zero
Warning[Lp012]: no sections with name CodeRelocateRam included - special symbol CodeRelocateRam$$Base (referenced from C:\Users\Peter Goddard\
Documents\Freescale Tower\Kinetis\hello_world\RAM_128KB\Obj\startup.o) will be zero
Warning[Lp012]: no sections with name CodeRelocate included - special symbol CodeRelocate$$Base (referenced from C:\Users\Peter Goddard\Documents\
Error while running Linker
The file startup.c contains the following snippet...
data_ram = __section_begin(".data");
data_rom = __section_begin(".data_init");
data_rom_end = __section_end(".data_init");
n = data_rom_end - data_rom;
The linker is using the standard file
$TOOLKIT_DIR$\examples\Freescale\K60\TWR-K60\GettingStarted\config\K60X_ram.icf
.data and.data_init are not defined in it so how do I define it?
Thanks in advance.
タグ(3)
495件の閲覧回数
jeremyzhou
Hi Peter,
Thank you for your interest in NXP Semiconductor products and the opportunity to serve you.
I'd highly recommend you to use the sample code of the TWR-K60D100M and its link is below.
https://cache.nxp.com/files/microcontrollers/software/app_software/code_examples/KINETIS512_V2_SC.zi...
Ping
