K22 Not Communicating
758 次查看
burgeh
I was brought a K22FN256LH12 board that I just got back from production, and when I plug the J-Link Pro in it instantly turns the LED red. I am also unable to communicate using the JLink commander. Below are images of the errors I keep getting. It says the protection bit is enabled it seems, and therefore I allow it to do a mass erase, but then it still cannot communicate with the board. Any thoughts or is this board shot?
Thanks!
614 次查看
kerryzhou
Hi Christopher,
    What's the K22 board you are using now? FRDM-K22?
   If yes, please choose the SWD instead of the JTAG, because this board is using the SWD, not the JTAG.
Wish it helps you!
Kerry
614 次查看
burgeh
This is a custom board, but it doesn't communicate through the SWD connector, both JLink and SWD work. I'm wondering if the chip is faulty or if it a board connection. I have a few other produced boards that do work.
614 次查看
kerryzhou
Hi Christopher,
  Now, what's the problem in the custom board? Secure?
  If yes, please let our customer check this post:
https://community.nxp.com/servlet/JiveServlet/download/857127-1-396709/Kinetis%20Lock%20issue%20anal...
This should be the customer board's hardware problem.
Kerry
