ISR code not working
1,003 次查看
vinkar
Hello Friends,
I have an unusual problem :smileyhappy:
I have designed 3 boards (variants of he same app) using the KL04 chip. Now the code used is this -
#include "derivative.h" /* include peripheral declarations */
//void UART0_IRQHandler(void);
// extern void LPTimer_IRQ(void);
// void LPTimer_IRQ(void);
int main(void)
    int count;
    uint16_t countTemp = 0;
   // asm(" CPSIE i");
    MCG_C1 |= 0x02;
    SIM_SOPT1 = 0;
    SIM_SCGC5 |= (SIM_SCGC5_LPTMR_MASK | SIM_SCGC5_PORTB_MASK);//PORTC_PCR1 |= PORT_PCR_MUX(1);//select RTC_CLKIN function
    PORTB_PCR3 |= 0x00000100;    // alternative pin mux selection //
    GPIOB_PDDR |= 0x00000008;    // pin direction //
    PORTB_PCR4 |= 0x00000100;    // alternative pin mux selection //
    GPIOB_PDDR |= 0x00000010;    // pin direction //
     NVIC_ICPR = 1 << (28);
     NVIC_ISER = 1 << (28);
     SIM_SCGC5|=SIM_SCGC5_LPTMR_MASK;
     /* Reset LPTMR settings */
     SIM_SOPT1 = 0;
     LPTMR0_CSR=0;
     LPTMR0_CSR |= 0x00000040;
     LPTMR0_CMR = 600;
     GPIOB_PTOR |= (1 << 3);
     GPIOB_PTOR |= (1 << 4);
      /* Start the timer */
     LPTMR0_CSR |= LPTMR_CSR_TEN_MASK;
      /* Wait for counter to reach compare value */
     asm("nop");
      while(1){
          asm("nop");
          asm("nop");
          asm("nop");
          asm("nop");
//         if((LPTMR0_CSR & 0x00000080) == 0x00000080){
//             LPTMR0_CSR &= ~LPTMR_CSR_TEN_MASK;
//             LPTMR0_CSR |= 0x00000080;
//             LPTMR0_CSR |= LPTMR_CSR_TEN_MASK;
//             GPIOB_PTOR |= (1 << 3);
//             GPIOB_PTOR |= (1 << 4);
void LPTimer_IRQHandler(void){
     asm("nop");
     asm("nop");
     asm("nop");
     asm("nop");
Ideally the controller should be interrupted and the control should go to the ISR (void LPTimer_IRQHandler(void)). What I see here is that in the 1st and the 2nd version of the board the ISR works well. But in the 3rd it doesnt. So, to test the 3rd board I made a pin toggle which is executed fine making me feel that this is a purely software issue.
I am a bit confused as to how this is being done.
I am stating the part number in all the 3 boards -
1) -  M04R4V
       4EYIDK
2) M04R5V
    4EYIDM
3) M04R5V
    ASAUK
Can anyone help me pls
标记 (1)
5 回复数
695 次查看
xiangjun_rong
Hi, Vinod,
Regarding your question, I have not the FRDM-KL04 board on hand, but I have FRDM-KL02Z board, I have tested the code on my FRDM-KL02Z board, I found out that the LPTMR0_PSR[PCS]=11 in binary for unknown reason  in default state, in the case, it selects the OSCERCLK as clock source, in the case, you should set the OSC32KSEL in SIM_SOPT1 as 10 in binary, in the setting, the CLK source for LPTMR will be from external RTC_CLKIN as Mr Yasuhiko pointed out, pls refer to section 3.8.3.3 LPTMR prescaler/glitch filter clocking options in RM of KL04. But if you use RTC_CLKIN pin, you have to enable PORTA clock in SIM_SCGC5 and set the PORTB_PCR4 = 0x00000100; and set the SIM_SOPT1 =0x80000;
I have developed the code based on the FRDM-KL02 board, with which I can enter the LPTimer_IRQHandler(void) with 1KHz LPO clock source, you can copy the code directly for KL04.
I attach the code, hope it can help you.
695 次查看
vinkar
Hello Xiangjun,
I understand ur point. But then how come it works in the other board but not i the new one.
Will nmi_b pin cause any mischief.
Vinod
695 次查看
vinkar
Hello Friends,
Thank you very much indeed for your responses.
I sincerely appreciate it.
SO with my code what I am doing is I am making the clock for the LPTMR come from RTC_CLKIN. And since I dont have such a clock its not working. So its all software.
But then how can it be explained that the LPTMR works for my older boards which also doesnt have the RTC_CLKIN. The code is completely the same.
Vinod.
695 次查看
xiangjun_rong
Hi, Vinod,
as you know, multiple clock source can drive the LPTMR, pls check the LPTMR0_PSR[PCS] to determine the clock source the LPTMR uses for your old code, I guess the LPTMR uses LPO, whatever.
Pls refer to the section I copied from UM of KL04.
XiangJun Rong
695 次查看
yasuhikokoumoto
Senior Contributor I
Hi vinod,
I guess your board has neither EXTAL0 nor XTAL0 oscillator. In the case, the setting SIM_SOPT1 0 would not select any clock for LPTMR. How about 0x000c0000 (i.e. LPO) as SIM_SOPT1 value? Also you should better make the first LPTMR0_CSR setting not 0 but 0x80 to clear the interrupt.
Yasuhiko Koumoto.
