I am trying to toggle the red led using TPM0_interrupt on FRDM-KL43Z
1,406件の閲覧回数
priyankavorugan
HI,
I am trying to toggle the red led using TPM0 _interrupt on FRDM-KL43Z board. I selected MCGIRCLK(8MHZ) as TPM clock source.
Since the prescaler is 2, the TPM clock period is 0.25microseconds.I  am loading the TPM_MOD register with 8000 so that the ON and OFF period of led is 2ms .
But the problem is irrespective of the value loaded in the TPM_MOD register the ON and OFF periods are 16.80ms and 16ms respectively. The following is the code .
SIM_SCGC6 |= SIM_SCGC6_TPM0_MASK ; //enable the clock for TPM0 module
SIM_SOPT2        |= SIM_SOPT2_TPMSRC_MASK ; //MCGIRCLK as clock source
TPM0_CONF      |= TPM_CONF_DBGMODE_MASK ; // increment the counter in debug mode
TPM0_SC             |= TPM_SC_PS(1); //PRESCALER IS 2
TPM0_SC             |= TPM_SC_CPWMS_upcounting ; //up counting is selected(0x08u)
TPM0_CNT         |= TPM_CNT_COUNT_MASK ; //clear the counter value
TPM0_MOD       |= TPM_MOD_MOD(8000); // to get a delay of 2msec
TPM0_SC             |= TPM_SC_TOF_MASK ; // clear the interrupt flag
TPM0_SC             |= TPM_SC_TOIE_MASK; //enable the interrupt
TPM0_SC             |= TPM_SC_CMOD(2); //TPM counter increments on every TPM counter clock
5 返答(返信)
886件の閲覧回数
priyankavorugan
Hi Alice,
I have checked the clock.It is 8MHZ.I tried the same with LPTMR and PIT.It worked well.I am facing problem with TPM.
anyway i will go through it again.
Thankyou.
886件の閲覧回数
Hello Priyanka,
Do you meaning no matter what the MOD register is , the interrupt timer is 16ms,
and you also be sure your code without any problem , maybe the TPM part have some
problem of your chip .
And you also can test my project.
Alice
886件の閲覧回数
Hello
About "But the problem is irrespective of the value loaded in the TPM_MOD register the ON and OFF periods are 16.80ms and 16ms respectively."  Do you meaning no matter what the TPM_MOD is , the ON time is 16.8ms, the OFF time is 16ms,
or you want set the e ON and OFF periods are 16.80ms and 16ms  ?
Alice
886件の閲覧回数
priyankavorugan
since i have loaded the mod reg with 8000 , the ON and OFF period should be 2ms.But when i measure it using DSO i am getting 16.80 ms nd 16ms respectively.
886件の閲覧回数
Hello Priyanka,
I create one TPM project about FRDM-KL43 on KDS refer to your parameter.
If you do not have the KDS IDE, i can show the registers:
selected MCGIRCLK(8MHZ) as TPM clock source;
the prescaler is 2;
TPM_MOD register with 8000;
and it can work well , each 2ms it will enter the interrupt and toggle the PTD5(LED) .
I check the waveform on the scope, it is right :
I also attached my project , you can use the KDS+KSDK to check it .
And about your code , please be sure whether the MCGIRCLK is 8M.
Hope it helps
Alice
