How to use RTC on FRDM-KL25Z board.
1,312件の閲覧回数
yasuhikokoumoto
Senior Contributor I
Hi all,
I am working on FRDM-K20D50M and FRDM-KL25Z boards.
Also I would like to use RTC to make MCU woken up from the low power mode.
In the FRDM-K20D50M case, it seems to be no problem.
However, in the FRDM-KL25Z case, the MCU hangs up when RTC_CR[OSCE] bit is set.
I think the reason would be because no 32kHz OSC was not equipped on the FRDM-KL25Z board,
For your reference, I will show my code below.
void RTC_init(void)
    SIM_SCGC6 |= SIM_SCGC6_RTC_MASK;// by this statement, hard fault becomes not occur
    RTC_CR |= RTC_CR_OSCE_MASK; //<= hanged up at this statement
    RTC_TPR = 0;
    RTC_TSR = 0xFFFFFFFF-5;
    RTC_TAR = 0;
    while((RTC_SR &( RTC_SR_TOF_MASK|RTC_SR_TIF_MASK))!=0);
    RTC_SR |= RTC_SR_TCE_MASK;  //<= although enabled RTC, count does not count up
If 'RTC_CR |= RTC_CR_OSCE_MASK' does not exist, the hanged-up does not occur.
However the overflow interrupt neither occur.
Could anyone let me know how to use RTC on FRDM-KL25Z board?
Otherwise, can RTC not actually be used on FRDM-KL25Z board?
Yasuhiko Koumoto.
タグ(3)
680件の閲覧回数
Kan_Li
Hi Yasuhiko Koumoto,
The RTC clock can be from the following sources, so you have to cogfiure which is for RTC before using.
Kan
2 返答(返信)
681件の閲覧回数
Kan_Li
Kan
680件の閲覧回数
yasuhikokoumoto
Hi Kan-san,
thank you very much.
according to your advice, I used LPO clock instead of 32kHz oscillator, and I succeeded to use RTC on FRDM-KL25Z board.
That is, I no longer use
but use
          SIM_SOPT1 &= ~SIM_SOPT1_OSC32KSEL_MASK;
          SIM_SOPT1 |=  SIM_SOPT1_OSC32KSEL(3); // 1kHz LPO
descriptions.
Best regards,,
Yasuhiko Koumoto.
