I am trying to do a temperature sensor measurement according AN3031 on FRDM-KL25. I used PE to generate the code. I can read stable results from ADC for tempsensor and for Vrefh but the internal bandgap is floating a lot. Even the +-3% accuracy of internal bandgap can not explain it.
The code is as "easy" as this:
AD1_MeasureChan(1, 0);
AD1_GetChanValue16(0, &adcvalue);
printf("ADC value: %d, ", adcvalue);
AD1_MeasureChan(1, 2);
AD1_GetChanValue16(2, &adcvalue);
printf("Bandgap: %d ", adcvalue);
AD1_MeasureChan(1, 1);
AD1_GetChanValue16(1, &adcvalue);
printf("Temperature sensor: %d, ", adcvalue);
AD1_MeasureChan(1, 3);
AD1_GetChanValue16(3, &adcvalue);
printf("Vrefh: %d \r\n", adcvalue);
ADC is in 16bit mode single ended 10us, low power mode, high speed conversion, async clock. With 1 conversion I receive completely insane values after bandgap read looks like it depends on the previous read, with 64 conversion it is from 20000-26000 which is way too much to do any reasonable calculation of the temperature. I can change the ADC properties but is has no influence on the results. I may be doing something completely wrong, but ATM do not see what.
已解决! 转到解答。
Please check my attached project, which use FRDM-KL25Z board to read bandgap voltage with ADC0_A.
Please check PMC_REGSC [BGBE] bit need be set to enable Bandgap generate voltage.
Wish it helps.
