Using the below PE settings I am able to transfer 8 bytes of data but my buffer contains 15 bytes of data. So whats the process of transferring all the data present in the buffer? I have used DMAT_Ldd component from PE. I am using FRDM-K20D50M board with codewarrior 10.5.
Kind Regards
Amit Kumar
Hello Amit,
You are using DMATransfer_LDD component that has been replaced by the new DMAChannel_LDD (already available in the CW MCU 10.5). See the thread https://community.freescale.com/thread/328100 (response from Marek Varecha).
Marek Neuzil
Hi Amit,
I didn't figure out the problem after I had a brief look through the screenshot you provided,
So I'm wondering if you could upload your project to the community.
I'm looking forward to your reply.
Ping
Hi Amit,
I think I've found the reason of why only 8 bytes have been transfered.
From your project, you set the [Transfer control]: Single transfer, when triger source:UART transmit exist, then DMA will transfer all 16 bytes to UART data register immediately.
However the UART0 have only 8-entry transmint FIFO which mean it can store 8 bytes and the FIFO will bypass other bytes.
Final, we've just received 8 byte from UART0.
Wish my support help.
Ping
HI Jeremyzhou
Thanks for the response, SO according to u if I change the transfer from single transfer to nested transfer it should work? I will test this and will update it soon.
Amit Kumar
Hi jeremyzhou
Thanks for the concern. Please find the attachment. The issue is when executing this program, the o/p i am getting is "hello wo" which is only 8 char, but my buffer size is 16 char. Following is the o/p.
Thanks & Regards
Amit Kumar
