I'm guessing I've just missed something in the data sheet, but I keep getting a hard fault when accessing PIT_MCR. I've reduced the code to a bare minimum:
void main(void) { PTA->PDDR |= (PORT_PUEL_PTBPE3_MASK | PORT_PUEL_PTCPE4_MASK | PORT_PUEL_PTCPE5_MASK); // enable RGB outputs PIT->MCR = 0; // enable PIT do { } while (1); }
This compiles fine (I left out the necessary includes here), and the accesses to PTA work (I've gotten the RGB LED changing colors), but the hard fault happens on the access to PIT->MCR, or any other PIT register. Here is the generated machine code:
PIT->MCR = 0; // enable PIT 2200 movs r2, #0 4B03 ldr r3, =0x40037000 601A str r2, [r3] ---- hard fault happens here
As seen, the address for PIT->MCR is correct, 0x40037000. The toolset is Segger Embedded Studio. If I do a RMW to change the PIT_MCR bit, the hard fault happens on the read access:
PIT->MCR &= ~2; // enable PIT 4A04 ldr r2, =0x40037000 6813 ldr r3, [r2] ---- hard fault happens here 438B bics r3, r1 6013 str r3, [r2]
Any ideas?
Most likely you need to enable the bus clock to the module, it will hard fault if you read or write any of the registers without the bus clock enabled. Set bit 1 of SIM_SCGC to enable the PIT module.
Thanks for the quick (and correct!) reply. I figured there was some enable I was missing. Now I just have to go back into the doc and figure out how I missed that. Thanks again.
