Freescale USB stack v4.1.1
1,625件の閲覧回数
izmile
I am using Freescale USB stack v4.1.1 on K22 processor. I am defining my device descriptors on RAM memory as shown below.
uint_8 g_device_descriptor[DEVICE_DESCRIPTOR_SIZE]=
DEVICE_DESCRIPTOR_SIZE,                /*  Device Descriptor Size         */
USB_DEVICE_DESCRIPTOR,                 /*  Device Type of descriptor      */
If I change the device descriptor (or any other descriptor) to FLASH area (as shown below) then I don't get proper USB enumeration.. Does Freescale USB stack work only with descriptors defined in RAM memory? I checked the K22 datasheet/reference, there is no restriction on the address in the BDT entry.
uint_8 const g_device_descriptor[DEVICE_DESCRIPTOR_SIZE]=
Could any one shed some light on this please?
-Ismail
ラベル(3)
742件の閲覧回数
mjbcswitzerland
Specialist V
Hi Ismail
The USB controller can't access Flash by default so you need to enable its rights in the flash access protection register:
FMC_PFAPR |= FMC_FPAPR_USB_FS;
The USB FS is bus master 4 in the K22 so
#define FMC_FPAPR_USB_FS
FMC_PFAPR_M4AP_RD
(which is 0x00000100)
Mark
Kinetis: µTasker Kinetis support
K22F: µTasker Kinetis FRDM-K22F support / µTasker Kinetis TWR-K22F120M support
For the complete "out-of-the-box" Kinetis experience and faster time to market
3 返答(返信)
742件の閲覧回数
Kan_Li
Hi Ismail,
If you put code running in flash as well, you might have to reconfigure the Crossbar Switch to let USB has higher priority than ARM core, please kindly refer to Priority Registers Slave(AXBS_PRSn) for more details.
Kan
742件の閲覧回数
izmile
Hi Mark and Li,
You both are correct. Now, I could make the USB working from flash.
Thanks a lot.
-Ismail
743件の閲覧回数
mjbcswitzerland
Specialist V
Hi Ismail
FMC_PFAPR_M4AP_RD
Mark
