FRDM-K64 PIN Digital Read
873件の閲覧回数
antonioangelm24
Hi.
I have a simple question. How do I use the DigtialRead function from Arduino in my FRMD K64 in C?. I need to read either high or low (1 | 0). I was trying this with the GPIOx_PDIR function but this doesn't write you a Logic 0 when the read is 0.
Can anyone help me out?
Thank you very much.
2 返答(返信)
746件の閲覧回数
mjbcswitzerland
Specialist V
Hi Antonio
If a pin is configured as GPIO (with clock gated to it) and its GPIOx_PDDR is '0' you can read its state in the GPIOx_PDIR register.
I don't have the impression that developers using the NXP forum use Arduino so you may find more suitable answers to your environment at the Teensy forum - the TEENSY 3.5 uses the K64.
In case you are making a transition from the Arduino world you can try the uTasker project (open source on Git Hub) since it also supports TEENSy 3.5 (and FRDM-K64F etc.), including simulation of the device/board so that you can more easily learn the internal workings. It doesn't constrain you to a certain environment since it is neutral and includes project for most common IDEs (MCUXpresso, CW, KDS, IAR, Keil, Rowley, Atollic, etc...).
Mark
746件の閲覧回数
antonioangelm24
Hello Mark,
Thank you for your answer. I'll get to that, and will check the uTasker you mencioned.
Thanks.
