Delay needed before setting USB0_CTL?
583件の閲覧回数
joeygouly
Hi all,
I found a weird issue in my USB code. Actually it's the Teensy LC USB code, that I have modified to run on MKL27Z.
In my code, I had to add a 1 ms delay before setting USB0_CTL, otherwise my code doesn't seem to work.
Link to code: keyboard-firmware/usb_dev.c at 26740e5dda0d72eb0681a865d16cf2588b6e7670 · jgouly/keyboard-firmware ·...
Is there anything I need to "wait" for before setting this? Or anything that I'm missing?
Joey
2 返答(返信)
350件の閲覧回数
bobpaddock
Senior Contributor III
I believe the problem is in the lines that are commented out before those, the one 'undocumented bit' and the reset controller lines.
This is what I use:
void usb_init( void )
  debug_write_err( "USB_INT\n\r", 5 );
  /* Clock gate and USB clock source: */
    SIM_SOPT2 |= SIM_SOPT2_USBSRC_MASK;   // Set USB clock source to MKL25:(PLL/2) or MKL27:IRC48M clock.
#if( defined( MCU_MKL27Z4 ) )
    SIM_SCGC4 |= SIM_SCGC4_USBFS_MASK;    // Enable clock gate for USB
#else
    SIM_SCGC4 |= SIM_SCGC4_USBOTG_MASK;
#endif
     * USB Module Configuration.
     * USBTRC0: USB Transceiver Control Register 0   *
     * Reset USB Module.
     *   NOTE: USBRESET bit is always read as zero. Wait two USB clock cycles after setting this bit.
     * Errata:
     *  Description: The USBx_USBTCR0[USBRESET] bit is not properly
     *               synchronized.  In some cases using the bit can
     *               cause the USB module to enter an undefined state.
     *  Workaround:  Do not use the USBx_USBTCR0[USBRESET] bit. If USB
     *               registers need to be written to their reset
     *               states, then write those registers manually
     *               instead of using the module reset bit.
     *  Mask Set Errata for Mask 2N97F, Rev 23 JUL 2013.
     * FIX ME:
    USB0_USBTRC0 = USB_USBTRC0_USBRESET_MASK; /* Reset USB Module; "hardware bug workaround" */
    nop(); /* nop() may actually consume no time */
    nop();
    nop();
    nop();
    USB0_USBTRC0 |= 0x40; /* Asynchronous Resume Interrupt Enable / Attach ColdFireV1 USB core to bus */
     * Set address bits of the base address where the current Buffer
     * Descriptor Table (BDT) resides in system memory.
     * Must to be on 512 byte boundary.
     * D8 Bit is masked in BDT_PAGE_01.
    USB0_BDTPAGE1 = ( (uint8_t)( (uint32_t) bdt >> 8U ) & 0xFEU );
    USB0_BDTPAGE2 =   (uint8_t)( (uint32_t) bdt >> 16U );
    USB0_BDTPAGE3 =   (uint8_t)( (uint32_t) bdt >> 24U );
     * Interrupt Enable register (USB0_INTEN)
     * Setting any of these bits enables the respective interrupt
     * source in the ISTAT register.
    USB0_INTEN  = 0x00;    /* Disable all IRQs, during configuration */
#if( defined( MCU_MKL25Z4 ) )
     * OTG Interrupt Control Register (USBx_OTGICR)
     * Enables the corresponding interrupt status bits defined in the
     * OTG Interrupt Status Register.
    USB0_OTGICR = 0x00;    /* Disable all OTG IRQs, during configuration */
#endif
     * Error Interrupt Enable register (USBx_ERREN)
     * Contains enable bits for each of the error interrupt sources
     * within the USB module.  Setting any of these bits enables the
     * respective interrupt source in ERRSTAT. Each bit is set as soon
     * as the error conditions is detected. Therefore, the interrupt
     * does not typically correspond with the end of a token being
     * processed.
    USB0_ERREN  = 0x00;    /* Disable all error IRQs, during configuration */
     * Interrupt Status register (USB0_ISTAT)
     * Contains fields for each of the interrupt sources within the USB
     * Module.  Each of these fields are qualified with their respective
     * interrupt enable bits.  All fields of this register are logically
     * OR'd together along with the OTG Interrupt Status Register
     * (OTGSTAT) to form a single interrupt source for the processor's
     * interrupt controller.  After an interrupt bit has been set it may
     * only be cleared by writing a one to the respective interrupt bit.
     * Clear any pending IRQs:
    USB0_ISTAT     =
        USB_ISTAT_USBRST_MASK |
        USB_ISTAT_ERROR_MASK  |
        USB_ISTAT_SOFTOK_MASK |
        USB_ISTAT_TOKDNE_MASK |
        USB_ISTAT_SLEEP_MASK  |
        USB_ISTAT_RESUME_MASK |
        USB_ISTAT_ATTACH_MASK |
        USB_ISTAT_STALL_MASK;
#else
    USB0_ISTAT     =
#endif
    device_state_u8 = (uint8_t) POWER;
     * Enable just the reset interrupt.
     * Reset will enable the other interrupts when the bus is reset.
    USB0_INTEN = USB_INTEN_USBRSTEN_MASK;
     * USB Control register (USBx_USBCTRL)
     * 1:Weak pulldowns are enabled on D+ and D–.
    USB0_USBCTRL = USB_USBCTRL_PDE_MASK;
     * Control register (USBx_CTL)
     * Provides various control and configuration information for the
     * USB module.
    USB0_CTL  =  USB_CTL_USBENSOFEN_MASK;       /* Module enable. StartOfFrame */
#else
    USB0_CONTROL = USB_CONTROL_DPPULLUPNONOTG_MASK;
    USB0_CTL1 =  USB_CTL1_USBEN_MASK;           /* Module enable */
#endif
    SIM_SOPT1 |= SIM_SOPT1_USBREGEN_MASK;       /* Enable USB regulator */
     * OTG Control register (USBx_OTGCTL)
     * Controls the operation of VBUS and Data Line termination
     * resistors.
    USB0_OTGCTL =  USB_OTGCTL_DPHIGH_MASK         /* D+ Data Line pullup resistor enable, starts enumeration */
                |  USB_OTGCTL_OTGEN_MASK;         /* The pull-up and pull-down controls in this register are used.*/
    enable_irq( INT_USB0 );
#else
    USB0_CTL0   =  USB_CTL0_DPHIGH_MASK;          /* D+ Data Line pullup resistor enable, starts enumeration */
    NVIC_EnableIRQ( INT_USB0 );
#endif
350件の閲覧回数
joeygouly
Hm yes, I uncommenting those lines makes the code work.
diff --git a/src/target/kinetis/mkl27z/third_party/usb_dev.c b/src/target/kinetis/mkl27z/third_party/usb_dev.c index 2187900..1ab5421 100644 --- a/src/target/kinetis/mkl27z/third_party/usb_dev.c +++ b/src/target/kinetis/mkl27z/third_party/usb_dev.c @@ -983,7 +983,9 @@ void usb_init(void)  #endif          // reset USB module -       //USB0_USBTRC0 = USB_USBTRC_USBRESET; +#define USB0_USBTRC0           (*(volatile uint8_t  *)0x4007210C) // USB Transceiver Control Register 0 +#define USB_USBTRC_USBRESET            ((uint8_t)0x80) +       USB0_USBTRC0 = USB_USBTRC_USBRESET;         //while ((USB0_USBTRC0 & USB_USBTRC_USBRESET) != 0) ; // wait for reset to end          SIM_SOPT2 |= SIM_SOPT2_USBSRC_IRC48M; @@ -998,10 +1000,8 @@ void usb_init(void)         USB0_ERRSTAT = 0xFF;         USB0_OTGISTAT = 0xFF;  -       //USB0_USBTRC0 |= 0x40; // undocumented bit +       USB0_USBTRC0 |= 0x40; // undocumented bit  -       // FIXME: Remove this delay. -       cmsdelay(1);         // enable USB         USB0_CTL = USB_CTL_USBENSOFEN;         USB0_USBCTRL = 0;
However, a few things are still unclear:
Your code has:
And then you just go on to using this bit:
So that seems odd!
Where can I find the current errata for new MKL27Z256VLH4s?
The MKL27Z document I have says:
USBx_USBTRC0
bit 6:
NOTE: Software must set this bit to 1b.
So that kinda confirms the need for "USB0_USBTRC0 |= 0x40; // undocumented bit", even though I don't seem to need that if I use my previous code.
