Deadtime insertion on FTM2 with FRDM-KE06Z
638件の閲覧回数
brunotremblay
I'm trying to the FTM2 channels 0 to 3 to generate Phase-shift PWM signal with the FRMD-KE06Z board as explained in the appnote "AN5142 Features of the FlexTimer Module" in the section 3.4. For generating Phase-shift signals there is no problem. It's easy to change the amount of phase-shift. However, I don't see any deadtime between the complementary channels CH0 and CH1 or CH2 and CH3. The only changes I made from AN5142 is using SIM_SCGC instead of SIM_SCGC6 to enable FTM2 module clock and changing FTM0_ for FTM2_.
I tried to change the value in the FTM2_DEADTIME register, but at the scope screen's there's no deadtime.
Here is the values of the registers:
SIM_SCGC          0x00003080
FTM2_SC             0x00000010
FTM2_MOD          0x000003E8
FTM2_C0SC         0x00000008
FTM2_C0V            0x0000000A
FTM2_C1SC         0x00000008
FTM2_C1V            0x000001FE
FTM2_C2SC         0x00000008
FTM2_C2V            0x000000FA
FTM2_C3SC         0x00000008
FTM2_C3V            0x000002EE
FTM2_MODE        0x00000005
FTM2_COMBINE  0x00001313
FTM2_DEADTIME 0x0000001E
Any suggestions?
Bruno
422件の閲覧回数
brunotremblay
Found the problem. Deadtime insertion doesn't work when fixed frequency clock is selected instead of system clock.
Bruno
423件の閲覧回数
brunotremblay
Bruno
