Compilation error for Freedom bootloader in KDS 3.2.0
714 次查看
dhanapal_rajend
I have a FRDM-K82F: Freedom Development Platform for K82, K81. I am trying to compile freedom_bootloader in KDS 3.2.0 and I am getting error. Document has the procedure for IAR but i am using KDS.
Document has below procedure
"Select C/C++ Compiler, and the preprocessor tab. Scroll down in the defined symbols. Note that all unused interfaces are disabled. This is done to save code size and remove un needed interfaces."
I am not seeing any respective setting in KDS.
If I try to compile then i am getting linker error.
Any comments please.
R.Dhanapal
标记 (1)
4 回复数
589 次查看
danielchen
Hi R.Dhanapal:
Just did a quick test on KBOOT with Frdm-k82, it can compile  successfully with KDS 3.2 on my side. I would suggest you download from MCU Bootloader|NXP  and try it again.
NXP_Kinetis_Bootloader_2_0_0\NXP_Kinetis_Bootloader_2_0_0\targets\MK82F25615\kds\freedom_bootloader
589 次查看
dhanapal_rajend
Hi Daniel,
I have a document "Payment Solutions Secure boot Lab Guide 1_r0.2" it has
the procedure for IAR but i am using KDS 3.2.0version. By any chance i can
get the KDS based document. This would be helpful for me to proceed further
in a quick way.
R.Dhanapal
On Thu, 05 Jul 2018 03:30:17 +0000 (UTC), "danielchen@fsl"
589 次查看
dhanapal_rajend
Hi Daniel,
Thank you very much for your support. Fresh copy of source is getting compiled. Old copy of source which is in my PC has some problem.
R.Dhanapal
589 次查看
mjbcswitzerland
Specialist V
http://www.utasker.com/kinetis/FRDM-K82F.html
In case of complications, KBOOT (and other) solutions are available at the link that build with all IDEs (http://www.utasker.com/kinetis/compilers.html)
Mark
