Bug in DMA transfers
1,132 次查看
aliasadzadeh
Dear All
I want to put a 4 element int to another 16 element int with DMA,
Here is the code
static uint32_t test_source[4]={1,2,3,4};
static uint32_t test_dest[16]={0};
//DMA
//Enable DMA MUX
SIM->SCGC6 |= SIM_SCGC6_DMAMUX_MASK;
// Disable DMA MUX channel first
DMAMUX0->CHCFG[0] = 0x00;
// Clear pending errors and/or the done bit
if (((DMA0->DMA[0].DSR_BCR & DMA_DSR_BCR_DONE_MASK) == DMA_DSR_BCR_DONE_MASK)
  | ((DMA0->DMA[0].DSR_BCR & DMA_DSR_BCR_BES_MASK) == DMA_DSR_BCR_BES_MASK)
  | ((DMA0->DMA[0].DSR_BCR & DMA_DSR_BCR_BED_MASK) == DMA_DSR_BCR_BED_MASK)
  | ((DMA0->DMA[0].DSR_BCR & DMA_DSR_BCR_CE_MASK) == DMA_DSR_BCR_CE_MASK))
DMA0->DMA[0].DSR_BCR |= DMA_DSR_BCR_DONE_MASK;
// Set Source Address
  DMA0->DMA[0].SAR = (uint32_t )&test_source;
// Set destination address
  DMA0->DMA[0].DAR = (uint32_t )&test_dest;
  // Set BCR to know how many bytes to transfer
  DMA0->DMA[0].DSR_BCR = DMA_DSR_BCR_BCR(64);
  // Clear Source size and Destination size fields.
  DMA0->DMA[0].DCR &= ~(DMA_DCR_SSIZE_MASK | DMA_DCR_DSIZE_MASK);
// Set DMA as follows:
  // Source size is byte size
  // Destination size is byte size
  // D_REQ cleared automatically by hardware
  // Destination address will be incremented after each transfer
  // Cycle Steal mode
  // External Requests are enabled
  // Asynchronous DMA requests are enabled.
  DMA0->DMA[0].DCR |= (DMA_DCR_SSIZE(0)
  | DMA_DCR_DSIZE(0)
  | DMA_DCR_D_REQ_MASK
  | DMA_DCR_DINC_MASK
  | DMA_DCR_SINC_MASK
  | DMA_DCR_ERQ_MASK
  //| DMA_DCR_CS_MASK
  | DMA_DCR_ERQ_MASK
  | DMA_DCR_EADREQ_MASK
  | DMA_DCR_EINT_MASK
  | DMA_DCR_SMOD(3)
  // Enables the DMA channel and select the DMA Channel Source
  //DMAMUX0->CHCFG[0] = 0x02; // Select UART0 as the Channel Source
  DMAMUX0->CHCFG[0] |= DMAMUX_CHCFG_ENBL_MASK; // Enable the DMA MUX channel
  NVIC_EnableIRQ(DMA0_IRQn);
  DMA0->DMA[0].DCR |= DMA_DCR_START_MASK;
void DMA0_IRQHandler()
  // Set Source Address (this is the UART0_D register
But After I run the code instead of getting 1,2,3,4,1,2,3,4... in test_dest I will get
1,2,3,4,0,1,2,3,4,0,1,2,3,4,0x02DC6C00,0
what is wrong with this Code?
4 回复数
626 次查看
Monica
Senior Contributor III
Ali, was this helpful?
Please let us know! :smileywink:
626 次查看
lothar
I would write:
  1. static uint32_t test_source[]={1,2,3,4};  // Compiler counts the array size itself
  2. static uint32_t test_dest[16]; // I think they are initialized to 0 anyway and like that you only put the first element to 0
Im not sure about this one. Your variable test_source is an array. Therefor in test_source[0] there is a one. But test_source without [] is a pointer, pointing to the first value of your array (*test_source is also = 1). So you probably like to write:
DMA0->DMA[0].DAR = (uint32_t )test_source;
or
DMA0->DMA[0].DAR = (uint32_t )&test_source[0];
At the moment you give an address of a variable in which a address is stored.
Maybe I'm wrong Smiley Wink
greez
626 次查看
JimDon
Just wondering did you mean | or || in your  if statements?
626 次查看
aliasadzadeh
I meant | (or) in my if statement, Do you know what's wrong?
