About external clock of KV58 tower board
535 次查看
sutter_zhou
Hi , the external clock source on KV58 tower board is 50MHz, but the allowable maximum clock of this source is 48Mhz according to datasheet. Also, when using clock generator on kex.nxp.com, this tool reminds that over 48MHz is not allowed, so I can't use this tool to generate clock configuration codes. Any comments?
320 次查看
kerryzhou
Hi Sutter zhou,
  Sorry for my later reply, I just get the reply from the according department:
Have confirmed with Design that this is a mistake in the KV5x datasheet and a 50 MHz input is fine.
  You can find details from this link:
https://community.nxp.com/thread/445714
Because we are colleague,  you also can post it in our internal community directly.
Wish it helps you!
Kerry
320 次查看
kerryzhou
Hi Sutter Zhou,
     About this point, I already check it with our according department in the internal community.
    After I get the reply, I will let you know!.
Kerry
