Hello.
Someone could tell me how to configure the serial bootloader (AN2295) to work with the head mk60f15.h, of kinetis?
Currently I have:
#define KINETIS_MODEL K60_100MHz
I am working with MK60FX512
What value should I put?
Thanks.
Thanks for the help and for the suggestion.
I have already managed to get my an2295 to work. I have used the FLASH_ProgramSectionByPhrases function instead of the FLASH_ProgramSectionByLongs and changed the headers as jeremyzhou suggested.
Best regards.
Hi Fernando Ramon ,
Please the following steps to add the MK60f15.h.
#elif KINETIS_MODEL== K60_150MHz
#include "MK60f15.h"
Ping
If you don't solve your problem you can get loaders [USB-MSD Host/Device, SD card, KBOOT, AN2295
Developer's Serial Bootloader and Ethernet Web Server] for almost all Kinetis boards/parts at
http://www.utasker.com/kinetis.html
Builds with KDS, CS, S32, IAR, Keil, Atollic, Rowley, Greenhills, CooCox, GCC and VS and allows real-time simulation for testing, debugging, analysing etc.
Mark
Hi Fernando Ramon,
Thanks for your reply.
However I'd highly recommend you to use the KBOOT instead of the AN2295, as the KBOOT is the newest bootloader solution.
Ping
