關於SDK
關於SDK
652件の閲覧回数
JetWen
我嘗試把NXP的SDK 導入IAR的IDE中,但是無法導入,想請問有甚麼我沒有考慮到的因素嗎?
4 返答(返信)
634件の閲覧回数
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, as normally when you download the SDK look at the image as an example.
You must select the IDE.
Pavel
586件の閲覧回数
JetWen
Can I import SDK in IAR directly?
or should I create a new project in IAR?
575件の閲覧回数
Pavel_Hernandez
Hello, the steps are, download the SDK, unzip the SDK, search for the example that you need to review, on the root C:\Users\mcuxpresso\01\SDKPackages\SDK_2_3_0_EVK-MIMXRT1050\boards\evkmimxrt1050
Then when you open the example on the IAR the IDE automatically will ask you to install the DSP and DFP click yes.
Pavel
560件の閲覧回数
JetWen
Hello ,I finally got it, thank you for your answer.LOL
