1.I encountered a issue that KDS said cannot build successful with “undefined reference asm”, may I avoid it by change some setting of KDS?
2. Back to CW when during debug, I can add any global variables as I want into the"variable window", with "refresh while Running", can use it to monitor some datar, for example,read I2C values:
But the add option always disable in kds, only I can put them into the expression window, where I could see the values changed after suspend the porgram running.
Is kds removed this function? If not, how to fix it?
thanks so much!!
Solved! Go to Solution.
Let me try to address your questions:
Cheers,
Antonio
Cheers,
Antonio
Thank you!
