The FRDM-K66F device is not showing in KDS 3.2
I remember the getting started link for the FRDM-K66F did have a special SDK 1.3 for the board FRDM-K66F but now this is missing.
The FRDM-K66F may be removed for some reason?
I have installed the special SDK onto one of the PC as a copy but the project generator not picking of this folder.
Any idea what is going on?
已解决! 转到解答。
My issue was the device FRDM-K66 was not showing in the device list.
File => New => Kinetis SDK1.x Project (Next) Devices => Boards => Kinetis
I still haven’t found a solution for this issue!
But it seems the SDK SDK_2.0_FRDM-K66F is the best way for loading samples as I can compile and run the sample code without any issue.
Hi Siva,
go to http://kex.nxp.com and create configuration for FRDM-K66F. You can download SDK 2.0 (latest version).
Marek
