Programming KL26Z128VLH4 microcontroller without using KL26Z128VLH4 microcontroller
970件の閲覧回数
hb0038
One of my project I want to use KL26Z128VLH4 microcontroller. These days I'm doing research on that. I found a development kit FRDM-KL26Z which is using KL26Z128VLH4 microcontroller. When I open the schematic diagram of this development kit I saw there is another microcontroller called K20DX128VFM5. https://www.nxp.com/downloads/en/schematics/FRDM-KL26Z_SCH_REV_B.pdf This schematic diagram says it is dedicated for OpenSDA purposes.
My question is Can I still program KL26Z128VLH4 microcontroller if I do not use KL26Z128VLH4 microcontroller?
Thank you
Harsha
4 返答(返信)
801件の閲覧回数
Carlos_Mendoza
Hi Harsha,
As you mentioned, the K20DX128VFM5 is used for the OpenSDA interface, the KL26Z128VLH4 can be programmed using this interface or it can also be programmed through the J7 SWD connector using an external programmer.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
801件の閲覧回数
hb0038
Hi Carlos,
Thank you for your advice. Could you please tell me the couple of external programmers which I can use to programme?
Harsha.
801件の閲覧回数
Carlos_Mendoza
Hi Harsha,
You could use LPC-Link2 or one of our partner debug probes:
 LPC-Link2|NXP
LPC Debug and Trace Probes|NXP
Hope it helps!
Carlos Mendoza
801件の閲覧回数
ZhangJennie
Hi Harsha,
What do you mean "still program KL26Z128VLH4 microcontroller if I do not use KL26Z128VLH4 microcontroller"? Can you please specify?
Jennie Zhang
