Hi, i have this simple operation : image->start_sector = (((char)(*buff))<<24)|(((char)*(buff+1))<<16)|(((char)*(buff+2))<<8)|((char)*(buff+3));
where i concatenate 4 byte in a 32bit variable. the problem is when i shift the buff+1 << 16. The number that i have to obtain could be 0x3b9b2a00 but i have 0xff9b2a00. The problem is visible in the image, the other shift work well.
解決済! 解決策の投稿を見る。
Hi Daniele,
your code assumes that plain 'char' is unsigned. However, plain char is 'signed', or at least this is what I believe you are using.
Check your compiler settings:
The correct way to write your calculation is
result = (((unsigned char)(*buff))<<24)|(((unsigned char)*(buff+1))<<16)|(((unsigned char)*(buff+2))<<8)|((unsigned char)*(buff+3));
Explanation:
*(buff+1)
is a char (signed char)
Then you even cast it to a (signed) char again (redundant from the compiler point of view)
((char)*(buff+1))
Then, before the shift (<<) operation, the compiler has to do integral promotion.
because this is a signed char (0x9b) and negative, it gets promoted to
0xff9b
and then ORed into your result.
So this is why you get 0xff9b.
Solution: take care of signed or unsigned char, and use unsigend char in that particular case.
I hope this helps,
Erich
Hi Daniele,
Explanation:
*(buff+1)
((char)*(buff+1))
0xff9b
I hope this helps,
Erich
