Post-build commands
823件の閲覧回数
davidsherman
Senior Contributor I
I am trying to invoke objcopy directly, because I'm trying to generate two S-record files.  I have a specific section which will be located in an external EEPROM that needs to be stripped.  In the help file, it says multiple commands can be separated by semicolons. I can use either of these lines individually:
${cross_prefix}objcopy -O srec -j.nvdata --change-section-address .nvdata=0x0 program.elf program_eeprom.srec
${cross_prefix}objcopy -O srec -R.nvdata program.elf program_main.srec
Either of these alone will generate the correct S-record file.  However, if I try to put them both in the post-build command box with a semicolon separating them, nothing happens.
I could make a batch file that gets called and does these two operations, but I'd like to avoid having the path to the Gnu tools hard-coded in it.
3 返答(返信)
572件の閲覧回数
davidsherman
Anyone?
573件の閲覧回数
BlackNight
572件の閲覧回数
davidsherman
Thank you again, Erich!  I've bookmarked that site.  Looks like lots of good information there.
