Is there a problem with HC-SR04 sensor and gpiosetevent in PX4 for Kinetis?
2,099 次查看
nxf58541
2,017 次查看
nxf58541
You may be correct that this function is not implemented. We have not used the ultrasonic sensors in any internal builds. I will ask a developer about it. Meanwhile - as it turns out - We (the drone team in NXP) will be adding a bonus challenge to an upcomoing NXP RT1010 contest to implement a multidirectional ultrasonic sensor - you may want to look for that later this month. The intention is to offload the sening to the RT1010 MCU, and then communicate back via SPI/Mavlink.
2,018 次查看
nxf58541
