flashback shows when creating new projects on FreeMaster
880 次查看
Vergil
Dear NXP Team
When I open FreeMaster, it stops here and shows these message. Then flashbacks happened.
865 次查看
MichalH
NXP Apps Support
NXP Apps Support
this is similar issue as reported recently here. It seems the August/2023 MS Windows or Edge browser update is causing some incompatibility between FreeMASTER and Edge interface.
As a temporary workaround, please rename the "c:\NXP\FreeMASTER 3.2\FreeMASTER\html" folder to "html.bak". When FreeMASTER starts, it will not find the welcome pages in this folder and will show a default empty content.
The "welcome" experience of the FreeMASTER will be limited and also the Edge HTML rendering is not functional, but at least some functionality remains.
We are looking into this issue now and hope to provide a better solution soon.
Michal
866 次查看
MichalH
NXP Apps Support
NXP Apps Support
Michal
842 次查看
Vergil
Dear Michal
THANKS. The problem was solved by using your method.
I hope NXP can provide a better solution to this problem soon.Thanks again.
Vergil
789 次查看
MichalH
NXP Apps Support
NXP Apps Support
the issue should now be fixed. Please update to 3.2.2.2 available at www.nxp.com/freemaster
Please close this thread if you test the hotfix successfully.
Michal
