Usage of project global constants
983件の閲覧回数
samilaster
Hi All,
I want to show variables in FreeMaster as REAL values and Im wondering if it is possible to define the factor as project global constant.
In my example I would like to write ScaleCurrent instead of 0.00048828.
And somewhere else ScaleCurrent = 0.00048828.
Is this possible? What is the best way to do this?
Many Thanks in advance
Sami
928件の閲覧回数
MichalH
NXP Apps Support
NXP Apps Support
Dear Sami,
you can store the parameter in the target MCU application as a value of a constant variable. Then you may define a FreeMASTER variable to access that value - set its Sampling Period to "once" as it is constant anyway. Then you may use that variable as a parameter in REAL value transformation of other FreeMASTER variables.
Michal
