How to prohibit freemaster from using j-link to connect to the chip (S32K144)
990 次查看
LIZQ
The S32K1xx chip can be connected using freemaster without any configuration. How can I disable this connection?
4 回复数
945 次查看
LIZQ
Is there a way to turn off or limit the standard BDM plug-in to protect the interface security?
954 次查看
iulian_stan
Hi @LIZQ,
Are you using PD-BDM (Packet Driven BDM) communication plugin ?
If so - you can disable it by updating the following definition in the embedded application (freemaster_cfg.h
#define FMSTR_DISABLE          1    /* To disable all FreeMASTER functionalities */
Note: FreeMASTER will still be able to connect to the board via standard BDM plugin to read and write target memory over debug interface. This plugin relies entirely on the J-Link Probe and on-target BDM/JTAG module and does not require FreeMASTER specific enablement.
944 次查看
LIZQ
929 次查看
iulian_stan
The topic you want to address (disable/secure debug interface) is not related to FreeMASTER.
You may want to check CSEc (Cryptographic Service Engine compressed) Security Module first.
More information/details can be addressed on S32K144 product community space.
