Writing to Flash memory kills MCU
658件の閲覧回数
sm0khey
Hello! I am trying to save a variable, which a user input, to the flash memory. I am using MC56F82... and the IFsh1 library. I disable the events and then erase the block and then write to the flash, but my MCU keeps dying, i have to restart it and flash it again to get it working. Any ideas on how to do it correctly?
タグ(3)
598件の閲覧回数
xiangjun_rong
This is the flash example code based on CodeWarrior for DSP56800E ver8.x.
Pls refer to it.
Regarding your question, the flash erasing/programming code must be located in flash and copied to p RAM, you have to run the erasing/programming code in  RAM to manipulate the flash.
Hope it can help you
XiangJun Rong
4 返答(返信)
599件の閲覧回数
xiangjun_rong
Pls refer to it.
XiangJun Rong
594件の閲覧回数
sm0khey
Thank you for the help!
597件の閲覧回数
xiangjun_rong
I attach the code here.
XiangJun Rong
623件の閲覧回数
sm0khey
up
