MC56F8355 start up
MC56F8355 start up
446 次查看
christophe_c
I use an MC56F8355 and it doesn't start when I heat it.
The RESET signal is OK but the RSTO signal stayes at 0.
Thank you for your help
Christophe
416 次查看
xiangjun_rong
I suppose that the MC56F8355 can run if you don't heat it.
This is the ambient temperature range the MC56F8355 can work.
Hope it can help you
XiangJun Rong
389 次查看
christophe_c
If the temperature is 25°C, it's OK.
If the temperature is 10°C or 50°C, it's not OK.
I changed crystal by a ceramic resonator 8MHz and I can start the µcontroller at 10 and 50°C.
Is it necessary to change the bit  register COHL which is at  1.
Christophe
366 次查看
xiangjun_rong
If you use 8MHz ceramic resonator, I suppose the COHL bit should be cleared.
Pls refer to section 5.11.5 Oscillator Control Register w/o Relaxation Oscillator (OSCTL) in MC56F8300UM.pdf
XiangJun Rong
