AMF-AUT-T2353 - MOSFET Based H-bridge Window Lift Implementation
This session will present the advantages of H-bridge based window lifters against relay based ones, new functionalities that can be implemented and how NXP MagniV S12ZVMB64 microcontroller provides a well-integrated solution for a window lifter end node. With integrated functionalities like: internal regulator, GDU, PMF, ADC, current sensing, input capture and LIN physical layer.
%3CLINGO-SUB%20id%3D%22lingo-sub-1100899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAMF-AUT-T2353%20-%20MOSFET%20Based%20H-bridge%20Window%20Lift%20Implementation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20session%20will%20present%20the%20advantages%20of%20H-bridge%20based%20window%20lifters%20against%20relay%20based%20ones%2C%20new%20functionalities%20that%20can%20be%20implemented%20and%20how%20NXP%20MagniV%20S12ZVMB64%20microcontroller%20provides%20a%20well-integrated%20solution%20for%20a%20window%20lifter%20end%20node.%20With%20integrated%20functionalities%20like%3A%20internal%20regulator%2C%20GDU%2C%20PMF%2C%20ADC%2C%20current%20sensing%2C%20input%20capture%20and%20LIN%20physical%20layer.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1100899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20session%20will%20present%20the%20advantages%20of%20H-bridge%20based%20window%20lifters%20against%20relay%20based%20ones%2C%20new%20functionalities%20that%20can%20be%20implemented%20and%20how%20NXP%20MagniV%20S12ZVMB64%20microcontroller%20provides%20a%20well-integrated%20solution%20for%20a%20window%20lifter%20end%20node.%20With%20integrated%20functionalities%20like%3A%20internal%20regulator%2C%20GDU%2C%20PMF%2C%20ADC%2C%20current%20sensing%2C%20input%20capture%20and%20LIN%20physical%20layer.%3C%2FP%3E%3C%2FLINGO-TEASER%3E
No ratings
Version history
Last update:
‎10-24-2016 03:25 PM
Updated by:
