Short Size
Short Size
1,205件の閲覧回数
carlosmscabral
Hello there,
Using the compiler option 4-byte integer, a short will have, always, 2 bytes?
I can't understand exactaly the definitions of uint32, uint16... and how the compiler handles them.
2 返答(返信)
318件の閲覧回数
admin
Specialist II
No, this is an architecture dependent.
But, sizeof(short int) is 2 bytes for all known to me 32-bit architectures.
> I can't understand exactly the definitions of uint32, uint16... and how the compiler handles them.
Regularly, UINT32 has the range from 0 to 2^31-1.
Regularly, UINT16 has the range from 0 to 2^15-1.
318件の閲覧回数
JimDon
Senior Contributor III
The purpose of uint32, uint16 etc. is that they are adjusted for the environment you are in so that they are always that size regardless.
So if you use uint32, and you change compilers, processor, or compile options these are adjustedt in one place, vs all over if you use unsigned int.
